gaskets for cam swap
Re: gaskets for cam swap
You'll need:
- 2 AIR tube gaskets (2x GMPN 12553617)
- 1 front engine seal (1x GMPN 12561244)
- 1 crank pulley bolt (1x GMPN 12557840)
And if you have a 98, you'll also need:
- 2 Water pump gaskets for 1997-98 model cars (2x GMPN 12559271)
Any GM parts department at a dealership will have, or can quickly get, all of those parts.
FWIW, Thunder sells a gasket replacement package for cam swaps. It comes with timing cover, crank seal, valve cover gaskets, water pump gaskets and balancer bolt. Give it a shot if it suits you.
