Procharger guys, what is your set up and what are you making?
I currently have AI 226 heads and a trex cam. with a port matches 92 mm Fast. I found a ok deal on a procharger and always wanted one. So what is your set up and how many pounds you pushing and what are you making. THanks
A better thread would be you to post your goals and what you want. Everyones setup varies from 500 to over 1000 horse. Here is mine.
https://ls1tech.com/forums/forced-in...s-finally.html
I have a very mild setup putting out 500 at the wheels LS1, GT2-3 cam, Stainless works
headers & 3" pipes 42 lb injectors with a Procharger P1. Everything flows so well the boost gauge never gets above 3 psi. could have gone bigger !
stock ls1
SLP catback
TSP 228R Cam 114lsa
Hooker longtubes and ORY
LS6 intake
D1SC & FMIC
Alkycontrol single nozzle
stock 241 Heads
4.13 pulley
Racetronix Pump & 60lb injectors
93 octane
Truck intake
3:73 motives
5800 RPM Made 598.8 rwhp @ 17* of timing with an 11.4AFR
SLP catback
TSP 228R Cam 114lsa
LS6 intake
D1SC & FMIC
stock 241 Heads
4.13 pulley
93 octane
Truck intake
3:73 motives
Stock L76 block
Pro Charger F-1D
Treadstone TR12 FMIC
Kooks 1 7/8 LTH
Corsa catback
GMPP CNC ported LS3 heads
ARP head bolts
New Era (228/240) cam
Lunati double valve springs
Yella Terra 1.7 Rocker arms
GM LS7 lifters
Manley chromoly push rods
GM MLS head gaskets
LS7 cam gear
Aeromotive A1000
FAST fuel rails
FAST FPR
FIC 1000cc injectors
-8 Teflon fuel line feed
-6 Teflon fuel line return
736 RWHP / 642 LBFT SAE @ 14psi w/ 4" pulley on 91 octane.
Getting tuned this week w/ 4.5" and 5" pulley to lower boost on E85
Before and After Procharger
Pro Charger F-1D
Kooks 1 7/8 LTH
Corsa catback
ARP head bolts
GM LS7 lifters
GM MLS head gaskets
LS7 cam gear
Aeromotive A1000
FAST fuel rails
FAST FPR
