maf fuse keeps blowing
My car just started doing this. As soon as i put in a new fuse, it blows. I put another fuse in with the hood popped an hit the throttle an it blew. What do i need to be looking for?
Open the underhood fuse block up. Theres a fuse called ENG SEN (dont quote me) it's probably the one thats blown. amirite?
Do you have long tubes? Your headers have probably melted the insulation on the O2 heater circuit wiring and shorted it to ground causing the fuse to blow. Jack the car up and trace your wiring. Don't forget to check the rear O2's as well. The rears may be rubbing up against the transmission crossmember.
The following users liked this post:
Asqaud24 (12-29-2020)
