Is there a way to use LS1edit to help with 02 heater codes with headers?
Old 04-07-2004, 08:50 PM
2001WS6Vert's Avatar
Default Is there a way to use LS1edit to help with 02 heater codes with headers?
I did a search and found that a lot of people get o2 heater codes after a header install. Can anything be done to lighten up the PCM sensitivity so the code does not trip?
Old 04-07-2004, 08:56 PM
J&JsTA's Avatar
Code 135 & 141 can be X out so they don't come on anymore or not turn on the SES light in the engine diagnostics menu
Old 04-07-2004, 09:49 PM
felton316's Avatar
Just change the codes to 'Type X= turned off"
Old 04-07-2004, 10:35 PM
aNuBiS's Avatar
Question
does that ONLY stop it from setting a code? or does it also stop it from affecting how the engine responds/reacts to the change its seeing..
Old 04-08-2004, 11:54 AM
KGSloan's Avatar
if you turn off the o2 heater codes do you still get the insufficient switching code? or is that a different code that you have to turn off? i'm pretty sick of clearing these two codes every couple of days when there is absolutely nothing wrong.
Old 04-10-2004, 10:39 AM
KGSloan's Avatar
anyone????
Old 04-10-2004, 11:04 AM
WhiteDeathLS1's Avatar
TTT, please! This same issue is aging me.
Old 04-12-2004, 11:14 AM
Rok
Rok's Avatar
TTT
I'm about to install headers too and am wondering the same thing here.
