Avg $ of cam install in 2010 camaro ?
What is the goin price for a Cam install on a 2010 Camaro at a good shop ?Also do I need to get rid of VVT setup, lifters if it is a big agressive ,max N/A with full exhaust 6 speed .
What are some of the best BIG cams for this car & how much have you gained rwhp ?
LS1Tech Premium Sponsor
On the L99 engine with VVT and AFM, we prefer to get rid of the AFM and keep the VVT technology! We offer the DOD Delete kit and cam packages for the VVT combos!
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I ran your MS3 for a long time & now is in one of my buddies cars...good cam !
The car already has full exhaust ,how much is cam kit + labor for install ,want most power N/A with a NASTY idle ,car is gonna be more strip than street but will be driven a fair amount on the street .
also OP $600-$1,200 labor
To delete DOD and Vvt you need to remove the heads and replace the the lifters with the regular Ls7 lifters, it's only 8 of them but I'd just replace all 16. You'll need to change the 1 bolt cam to a 3 bolt and get a 4x cam sprocket, Ls2/3 valley cover, Ls2/3 front timing cover and of course tuning it out, that's what coves off the top of my head.
I have read that some believe it is better to delete all VVT/afm with a large cam on the ls3's it just makes everything work better & less troublesome .Anybody else have input on this with a BIG NASTY cam for N/A .
Thanks for all the input ,I figured around $900 on labor on the Cam install was not bad but what if they do the heads & lifters ....how much more ?
