cam swap questions on 5.3
Old 09-19-2012, 08:45 PM
sweetk30's Avatar
Default cam swap questions on 5.3
got a 03 5.3 swaping into 85 truck. no reflash yet on pcm . stand alone conversion on stock harness. stock truck manifolds.
guy local has a new ls6 cam in the box for 250 bucks.
is this a good upgrade for the 5.3 ? and if so price good ?
if its a good upgrade what other parts are needed ?
i admit i am super new at the ls stuff. but learning . thanks for the help guys .
Old 09-19-2012, 08:46 PM
aknovaman's Avatar
Overpriced for a stock cam imo.
Old 09-19-2012, 08:49 PM
msydow's Avatar
its not really worth the work for the small gain unless you are going turbo or blower. even then i would get a custom cam. just my 2 cents. you wont get any "cammed" sound or anything. maybe 15hp at the wheels. im sure others will say im wrong but ive swapped a few cams and i would rather feel like i acheived something afterwards. not a stock idle and 15hp.
Old 09-19-2012, 10:03 PM
i r teh noobz's Avatar
I think you need LS6 springs as well. I'd pass. A decent cam kit (cam, springs, pushrods) is under 1k.
Old 09-19-2012, 10:35 PM
Jake Spoon's Avatar
15hp for a couple hundred bucks, while the motor is out, doesn't sound bad to me.
Old 09-19-2012, 11:46 PM
STEEPSS's Avatar
Save your money. You'll need pushrods, valve springs, timing chain, etc. to do it correctly. Why half-*** it?
Old 09-20-2012, 05:54 AM
sweetk30's Avatar
thanks guys.
prob best to just finish the truck first and then mabye ge fast parts later.
Quick Reply: cam swap questions on 5.3
