ZR1 injectors in a LS7
I bought a low mile used set of ZR1 injectors for my upcomming LS7 Z06 heads 'n cam project. Did I mess up?? Are they compatable? Any insight or suggestions would be very helpfull!
7 Second Club
I wouldn't use them as there are other injectors that would be a better match. The ZR1 injectors have a slightly different spray pattern at a slightly different angle because they are stood up in the ZR1. It will more than likely be spraying the port wall and not the valve like it's supposed to.
