S-10 truck brake Questioned
Old 09-21-2012, 11:22 AM
Double J's Avatar
Default S-10 truck brake Questioned
ABS light coming on, but doesn't stay on all the time, sometimes when applying brakes pedal pulses and brakes make a bumping sound. Can't tell if coming from front or rear. Thanks in advance.
Old 09-22-2012, 04:01 PM
Double J's Avatar
bump please
Old 09-23-2012, 05:23 PM
buellxb12s's Avatar
Abs module mine started like that and eventually stayed on ask the . You can pick a used fairly cheap. Some found wheel sensors to be at fault but usually it was the module.
Old 09-30-2012, 10:32 AM
Double J's Avatar
Thank you bro,
Quick Reply: S-10 truck brake Questioned
