brake line help
Old Sep 29, 2012 | 07:20 PM
97badass's Avatar
Default brake line help
Anyone have tips on replacing the hard lines? Is there a company that makes premade lines? Or what would you recommend for doing the abs delete?
Old Sep 29, 2012 | 07:44 PM
garygnu's Avatar
go to your local auto store and buy some brake lines,get the right threaded fitting ends.use a cut coat hanger for a template and length checker.
Old Sep 29, 2012 | 10:20 PM
libertyforall1776's Avatar
Wow, this question keeps popping up -- did you do a search?!
See:
http://www.flynbye.com/id71.html
http://www.sjmmanufacturing.com/cam_brk_ls1.html
http://www.inlinetube.com
Old Sep 29, 2012 | 10:35 PM
97badass's Avatar
And none of those links had what i was asking for. I have searched all evening to no avail. Asked a simple question got a smartass answer that was no help. Typical of ls1tech.
Old Sep 30, 2012 | 09:42 AM
cookba's Avatar
local parts store should have them, if not SDPC use to have them, I am sure they still do.
Old Sep 30, 2012 | 11:05 AM
Lol, you did not look at the links then, because the pre-made hardlines were there, at least for the rear:
http://www.flynbye.com/catalog/c3_p1.html
