please confirm my pushrod length befoe I order
I got a '99 TA with LS1 ,its got prc heads with ms4 cam ,Ls7 lifters and Harland Sharp 1.8 Non-Adjustable Rockers.i measure around 7.445 to 7455 on exhaust and 7.465 on intake at zero lash. but i dont know what to allow for preload. I can order 7.475 but I dont know if they be the right ones.
I would appreciate any help
LS1Tech Premium Sponsor
How did you measure those lengths? Are you using a dial caliper and measuring the adjustable pushrod tip to tip? Or are those the results of counting the turns to get back to the short length and multiplying that by .050"?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
these were measured tip to tip with dial calibers
