Wiring Harness for ABS Module???
Hello, I was wondering if there is a separate wiring harness for the ABS module on LS1 cars? The wires that go to the module were accidentally cut, and I'm wondering if I can just use some solder or even butt splices to put the wires back together, or if I can actually just buy a whole new harness?
I figured the wires could just be spliced back together, but I wasn't sure if that would create some sort of resistance that the ECM wouldn't like.
Thank you for any help.
It's part of the harness that comes from your driver side firewall. I've heard of people cutting it off like yours is when doin an abs delete kit for weight reasons. I'm sure it could be spliced back in if you could find someone with the part they cut but might as well just so the abs delete kit yourself since its cut.
