Z06 Maf freq, spark, PE, IFR, and VE tables wanted
Old 04-08-2004, 04:49 PM
FDLS6's Avatar
Lightbulb Z06 Maf freq, spark, PE, IFR, and VE tables wanted
I've got a 2000 fbody pcm, and Hptuners vcm edit that I'm using with a built ls6 motor. I'd like to import, or use as reference several tables from the Z06 pcm. If anyone has these, I would really appreciate taking a look. Thanks in advance
Old 04-09-2004, 01:01 PM
Moderator
jimmyblue's Avatar
I have an 01 Z06 table but that's all (for Z06)
in my collection. MAF changed for '02-up. I
think the place you're going to get the most
traction for this request is on HPTuners.com
and LS1Tuning.com (the latter being for Edit
and a much larger (currently) user base. Let
me know if this older MAF is the one you want
the table for. Conversely, if you do get one for
'02-up I would be pleased to add that to my
collection.
Old 04-09-2004, 01:23 PM
HumpinSS's Avatar
You can get the maf table from ls1howto.com
Old 04-09-2004, 03:12 PM
FDLS6's Avatar
Thanks guys.. Got it from the ls1howto site. Now if I can just round up some of the other tables. I'll try a post over at hptuners
Old 04-12-2004, 07:55 PM
Bill's 02 Z-28 SS's Avatar
Hi folks
I have just installed a LS6 Cam and ported LS6 heads into 2002 SS. I also have SLP headers and 36lbs injectors. I need LS6 data also, where did you find the data on ls1howto site. That is a great site, it helped me with my install.
Thanks
Bill
Old 04-12-2004, 09:21 PM
Bink's Avatar
I uploaded my stock 2001 Z06 file to LS1Edit.com for you guys. There are several 2002 and 2003 files available also. Here's the link;
File Library Link
Good Luck!
joel
Old 04-14-2004, 05:13 PM
FDLS6's Avatar
Thanks Bink.. however I have hptuners, not ls1edit, so I can't read your file.. Do you have any of the tables in excel by chance? Thanks
Bryan
Old 04-14-2004, 05:40 PM
AnthonyR's Avatar
post or pm me your email and I can send you the files that you need. I am pretty sure ls1edit will only allow me to export to a text file though. Would that be good enough?
