Bought some new parts for the car
Old 09-29-2012, 11:32 PM
BlackImpSS's Avatar
Default Bought some new parts for the car
Well I ordered a set of depo lights, and have already installed them.
Also just received everything I need for the gxp brake swap. I will post some pics after I get everything cleaned/painted. Hopefully these will be installed on Friday.
Just ordered a zzp shorter dog bone/ spring blockers from supercatxr7.
And waiting on my SS badge for the grill.
Old 09-30-2012, 06:05 AM
straitchev's Avatar
can you share part #s for GXP swap?
Old 09-30-2012, 08:00 AM
BlackImpSS's Avatar
I bought everything off a member here, so I don't have the part #. When I'm cleaning/painting everything if there are part #'s on everything ill be sure to write them down and post it up later. I know zzp sells a gxp brake kit for the front and rear so I am sure you could find the part # there.
Old 09-30-2012, 09:38 PM
BlackImpSS's Avatar
Here are a couple pics of the Brake components cleaned up.
Front rotor before and after
Front Caliper - Just cleaned it up a bit
Front/ Rear Rotors and Brackets finished
I will add some pics of the brakes on the car. I hope to install them on friday as long I can find someone to push the brake pedal so I can bleed the brakes.
Old 10-08-2012, 07:54 AM
WantanLS4's Avatar
Looking good.
Old 10-08-2012, 08:00 AM
BlackImpSS's Avatar
Thanks! Hopefully ill get a pic of the depo headlights and the SS badge up tonight. It was 50 and raining on Friday, so I didn't end up getting the brakes put on yet. Hopefully sometime this week. It should be a huge improvement.
Quick Reply: Bought some new parts for the car
