231/237 or G5X-3
Old 04-08-2004, 09:25 PM
nikejr16's Avatar
Default 231/237 or G5X-3
Hey everyone
I will be building a new motor for my car, and was wondering what cam to go with. I have heard alot of good things regarding the TSP cam, and also with the G5X-3 cam. I know its a newbie quest., but what is the specs on the G5X-3 cam?
Thanks,
Joe
Old 04-08-2004, 09:41 PM
1BADFNZ's Avatar
Yeah I'd like to know as well.
Old 04-08-2004, 09:48 PM
Beast96Z's Avatar
The specs on the X3 are still unreleased to the public, although a few of us know. When comparing the 2 cams, there really nothing alike. The X-3 is much more severe on the valvetrain due to faster ramp rates, and the TSP is on a much "softer" ramp rate which will be easy on the valvetrain. When it comes down to it, the X-3 will make better power "under curve" due to the faster rate getting the valve open sooner. It will also make better peak because it is a bit bigger than the 231/237. When it comes down to it, do you want mild or wild?
Old 04-08-2004, 10:01 PM
1BADFNZ's Avatar
Well I'm not planning on using it on my stock heads. Will the PP STG 2 LS6 heads handle it or not?? I don't want to have to rebuild the heads in a year or so.
Old 04-08-2004, 10:04 PM
nikejr16's Avatar
would it be better to get the X3 on a 112 or 114?
Old 04-08-2004, 10:36 PM
SSean's Avatar
Supposedly with the 112lsa X3 cam, you have to notch the pistons for clearance
Beast96Z's Avatar
The X-3 on a 112 will require flycutting your pistons. The 114 on the other hand is as tight as you can go on P/V clearence without cutting. If the heads are milled any at all, either cam will require fly cutting. The Patriot LS-6 style will compliment the cam very well. You won't have to have the heads"rebuilt". You will, on the other hand, have to change springs more often. Prolly about every 15,000 miles or so. The springs the Patriot's come with are also the exact spring you would want for this application.
Old 04-08-2004, 10:43 PM
1BADFNZ's Avatar
Thanks for the info
Now forgive my ignorance but how hard is it to replace the springs?? And is that with all hard running or not?? I tend to be soft most of the time when not racing
Old 04-08-2004, 10:50 PM
nikejr16's Avatar
Thnks for the info
Old 04-09-2004, 09:22 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Our 231/237 cam has and will clear on heads cut .010" with stock, uncut pistons. Granted it's a tighter squeeze, but it clears enough for even a 6 speed car to feel comfortable. With this cam and the "Gold" series springs on your heads, you should be able to run 25,000 give or take before needing to check the spring pressures. Give us a call if you have any other questions about your cam selection
-Matt-
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 04-09-2004, 10:24 AM
Beast96Z's Avatar
Originally Posted by Rice Eater 316
Thanks for the info
The spring getting weaker has to do with the style of lobe itsself. If the car is running, it's hard on the valvetrain. Granted you might get a couple extra thousand miles if you are easier on them, but t is still rough. A spring swap is pretty easy if you have the right tools. The tool from MORE performance is showing to be the best as far as ease of use and price. Just pull the plugs, rotate whichever cylinder you are working on to TDC, and use the tool to pull then reinstall the springs. The TSP cam is better if you do not want to have to mess with any of this. You'll make a bit less across the board, but you have no maintnence either.
Old 04-09-2004, 12:27 PM
rons 00z's Avatar
cant you hook your air compressor up through your plug hole and blow air into it as well?
Old 04-09-2004, 06:58 PM
Beast96Z's Avatar
You can if you have the spark plug fitting that adapts to a air hose.
Old 04-09-2004, 09:09 PM
1BADFNZ's Avatar
Cool man that's what I was looking for, I'll give up a little for less hassle and maintenance
