Engine swap help
Engine swap help
Real quick i have a 00 ss that i hit a deer with so i bought a new one without a engine so im gonna do a transplant my question is whats the eaiest way to pull a complete engine from the ss without a lift? I know several waysnto remove it but i dont want to pull the heads off my ls6 im just swapping the engine out then im gonna part out my other ss but i gotta do it in my garage anyone got any tips to make life a bit easier
you mite need a engine hoist and can left the engine from the top,removing the hood mite make it easier.have seen a guy on here that loosened all the K-member bolts and lifted the front of the car up with a good engine hoist,leaving the engine ,K-member and front tires on the ground.
Engine can come out the top but it's way easier out the bottom... That's how I did mine, in a driveway under a carport. Unhook everything then all that holds it up it 6 k-member bolts and 4 trans crossmember bolts.
