Dumb question - Engine Idle
Tried searching couldn't find. I have a 2000 Z28 A4. Idle in drive is about 650rpm according to the stock tach. Is this too low, and is there a way to raise the idle properly? Car runs and drives good. Just wondering.
LS1Tech Administrator
Received 1,523 Likes
The stock tach is almost never 100% accurate. You will need a scanner if you want to confirm the true idle rpm.
Stock GM tuning for these cars results in the following commanded idle speeds:
A4 cars: 650rpm in park/neutral, 550rpm in gear
M6 cars: 800rpm
The above is true for all years of LS1 F-body.
Idle speed can be modified via custom tuning. As these engines have an IAC motor to maintain commanded idle speed as temp and load conditions change, there isn't much you can do to adjust idle speed without some negative side effects (other than the proper method, which is custom tuning to change the commanded idle in the PCM).
M6 cars: 800rpm
there is a idle adjustment screw on throttle body. it is upside down, cant see it without mirror. takes a small torx bit, cant remember size. unsure about how it will affect stock tune though.
Posted from LS1Tech.com App for Android
Thanks bunches guys, had a 04 GTO m6 and it idled around 800, its tach was very accurate. I just though 650 seemed a bit low but if that's what GM tuned to probably had a reason.
If you have a stock cam, there shouldn't be any need to adjust the idle speed.
