Roller Rocker Question
Old 10-13-2012, 10:19 AM
Undertow74's Avatar
Default Roller Rocker Question
So i have my AFR 215's, LS7 lifters, Roller rockers,new push rods etc installed and all torqued down. Yes i measured for correct push rod length. My question is: when the valves are completely closed and at the top, should i be able to *slightly* wiggle the Roller rocker and the roller on the tip of the rocker spin by hand? I just happened to notice this today as i was getting ready to close up my garage for the day. I appreciate any input. thanks guys!
Old 10-15-2012, 04:52 AM
vettenuts's Avatar
If you haven't fired the motor yet, yes you will be able to do this although there isn't much slop in the roller rockers side to side.
Old 10-15-2012, 05:26 AM
bww3588's Avatar
Yes, once the lifters pump up, that slop should be gone.
Old 10-15-2012, 06:22 AM
Undertow74's Avatar
Oh yea, i am retarted. there is no side to side movement just a little bit up/down. Forgot i havent started it up and primed the lifters with oil. Ok, my worries are gone now. i knew there was no way in hell i needed longer pushrods haha
Quick Reply: Roller Rocker Question
