Would this work to keep a/c with a truck mani kit?
Old 10-24-2012, 05:34 PM
sweet99ss's Avatar
Default Would this work to keep a/c with a truck mani kit?
Here is an alternator relocation kit for $160 that mounts it to the top drivers side..
http://www.ebay.com/itm/New-LS1-High...item1e7343e364
And here is a kit that comes with everything needed to remount the a/c compressor to the top left and comes with a sanden compressor for $397.
http://www.currentperformance.com/Swap_Parts/AC.html
Old 10-24-2012, 06:18 PM
LS1CMR's Avatar
Maybe...
Old 10-24-2012, 07:25 PM
sweet99ss's Avatar
Originally Posted by LS1CMR
Maybe...
lol thanks
Old 10-24-2012, 07:52 PM
LS1CMR's Avatar
Originally Posted by sweet99ss
lol thanks
Not trying to be an ***. It might but I think it will be too wide and hit the shock towers. Email those guys and get some measurements and check for yourself.
Old 10-24-2012, 08:14 PM
LT1RAY's Avatar
It looks like the belt would be in the way of the truck manifold....could also be the angle of the picture. Where did you plan to put the A/C compressor?
What about these guys? http://kwikperf.com/
Old 10-24-2012, 08:52 PM
sweet99ss's Avatar
Yea after going and actually looking at my car there is just no way the a/c compressor is going to fit there.... I think the alternator would work with some moving off the abs unit, but the compressor is going to hit the shock tower... Back to looking for ideas to keep the car cool without a/c lol....
Old 10-24-2012, 09:04 PM
sweet99ss's Avatar
Look at the cooling cusion
http://www.youtube.com/watch?feature...&v=1ok6ntz8zY4
Old 10-24-2012, 10:14 PM
SPRAYED 01's Avatar
Dude why not just use a c6 manifold on the pass side and end it? I don't Get why people sacrifice ac and a sway bar for no reason at all.
Old 10-24-2012, 10:23 PM
ttranssam's Avatar
because that requires a bmr k member...usally truck manifold kit ppl are on a budget an that kit does not fit budget
Old 10-25-2012, 06:50 AM
SPRAYED 01's Avatar
Really? You're going to relocate an ac compressor, make custom lines, and god knows what else and get rid of the sway bar... Or order a $350 k member (200 used) loose a bunch of weight and leave everything alone.
Old 10-25-2012, 12:55 PM
sweet99ss's Avatar
Is it true without the a/c the defogger won't work? Like when it's rainy and your windows fog up you won't be able to defog it ?
Old 10-25-2012, 01:10 PM
SPRAYED 01's Avatar
Yes, the ac takes the moisture out of the air.
Old 10-25-2012, 01:21 PM
sweet99ss's Avatar
I've heard that, but I've also heard a/c isn't needed all you have to do is turn the defogger on and the air blowing against the window will clear the fog
Old 10-25-2012, 01:32 PM
ultradriver10000's Avatar
You can turn on the heat and it will take away the fog as well.
Quick Reply: Would this work to keep a/c with a truck mani kit?
