C5R Timing Chain + LS2 Dampener + 3-bolt Cam gear??
I'm doing a cam swap in my 2010 Camaro. I will be swapping out the single bolt stock cam for a 3-bolt TSP 231/236 cam.
During the swap I would like to install:
- C5R Timing chain
- LS2 Dampener
- 3-Bolt Cam gear (4X reluctor)
Are the 3 of these compatible? I've been told the LS2 Dampener will not work with this cam gear?? Can someone confirm/deny this?
- C5R Timing chain
- LS2 Dampener
Here too
http://www.lingenfelter.com/mm5/merc...Store_Code=LPE
Yes it's all compatible, that's the way to go if you ask me, the spring tensioner sucks.
Here too
BTW...how's the weather out there?
I'm going with the block of plastic. I like the idea behind the ls3 spring loaded one, just not it's reputation for failure.
I'm ready for summer. I hate cold weather, and this frankenstorm **** is not helping.
My pile is coming along. I got a mountain of **** in my garage my friends dumped off last week they haven't got out yet, but everything is machined ready to go. Just need odds and ends here and there. It's the nickel and dime stuff that is gonna kill my tax refund.
I got 2 350's to build and a 5.3 for my friends before any of my car stuff takes place. Wanna come help?
Just replacing the chain, gear and tensioner alone will not ensure trouble free times ahead.
The best way to ensure your engine is protected from chain failure is with a Cloyes Billet set. They include the C5R chain, 'oversized' cam & crank gears - eliminating the slack found in stock applications and other aftermarket sets, billet hardened gears and torrington roller bearing.
For best practice also fit an LS2 damper to prevent the chain from whipping back under rapid deceleration - the main cause of chain failure.
Part #'s:
9-3672TX9Z - kit with gears, C5R chain, 3 bolt cam, 4X sensor
9-5491 or 12581276 - LS7 damper (includes bolts) OR
9-5417 or 12588670 - LS2 damper (includes bolts)
The LS2 & LS7 dampers are interchangable on engines without a dry sump oil pump as the only difference is the LS7 damper is 1.1m thinner to clear the dry sump oil pump. The reason they are a different colour is to identify the parts when assembling engines at the factory.
Cheers!
Part #'s:
Cheers!
Moderator
Sorry for a bit of a hijack, but would appreciate other opinions on this. (I assume that "damper" is "harmonic balancer".) I have an LS2 and am considering an underdrive ATI balancer which is much lighter than the stock balancer and don't want that to increase risk of chain failure. Thanks.
Moderator
Thanks! I've seen the harmonic balancer called many different things and therefore wanted to be sure. End-of-hijack. Sorry.
