Time to rebuild my motor
Old 11-02-2012, 11:17 AM
Darkrider02's Avatar
Default Time to rebuild my motor
Hey guys I'm planning on building my lq4. Thinking
of throwing on a ls3 top end with a cam. What do you
guys think the power range will be at? I'm aiming for 500 n/a. Would throw nitrous later down the road....
Old 11-02-2012, 01:02 PM
sic7camaro's Avatar
So what are you building and what cam are u gonna run? Can't tell you the power or guess.can we tell you power range!?lol.
Well this is what I was gonna do almost same lq4 and ls3 heads
heads milled.030
G6x3 cam
Vic jr intake
Accufab 4150
1 7/8 headers
3inch exhaust
Was hoping for 480 rwhp
Try and get the compression close to 11:1 do some search and find what works and see what other builds are putting down.
Old 11-02-2012, 01:30 PM
wildcamaro's Avatar
If going with a mild or higher camshaft you should easily be looking at 450rwhp...like the other guy said get your compression up around 10.5-11:1 and depending on cam you should be able to meet your goal.
Old 11-06-2012, 06:04 PM
jeff keyuk's Avatar
make it easy, go pickup a crate motor 427,and ecu ! drop them in and go ! No troubles!
Old 11-06-2012, 06:09 PM
garygnu's Avatar
what intake would you use ?get a custom cam with the proper duration split to match the head flow split.
Old 11-06-2012, 06:55 PM
KCS
Moderator
KCS's Avatar
Most of the LS3 headed combos I've seen are making 450-480whp with unported heads and intake. I wouldn't expect much more than that.
Quick Reply: Time to rebuild my motor
