timing chain
Old 11-03-2012, 01:50 AM
415Z28's Avatar
Default timing chain
When should u change a ls1 timing chain? Got 103,000 miles.
Old 11-03-2012, 10:01 AM
conan's Avatar
I replaced the stock chain with a ls2 in my 5.3L at 220,xxx when I rebuilt the motor. Chains aren't like timing belts that to to be changed every 100,000.
If your planing on a cam swap or have to replace the oil pump ect I would throw a new ls2 on while your in there.
Old 11-03-2012, 10:45 AM
wildcamaro's Avatar
What year is it? If its a 98 or possibly an early 99 it will have a first design timing chain, but that being said I wouldn't tear the motor apart just to change it unless doing a cam swap or if you have a problem with the chain jumping time...
Old 11-05-2012, 03:49 PM
the_merv's Avatar
What's different about the 98 chain?
Old 11-05-2012, 04:17 PM
Sales1@Texas-speed's Avatar
Wouldn't be a bad idea to swap, but I would wait until you have everything tore apart for a cam swap unless thats something you don't intend on doing for a while.
Quick Reply: timing chain
