Whats this part called and where can i find it?
The part is between the distributor and goes in the engine hole.has teeth on both sides. about 1 1/2 inch
Im replacing the opti and somehow got stuck to it.The 1st time i changed it came off the old distributor so i reused it.
Cant find it anywhere.(online,shops,dealership)
And it may be called the distributor rotor??
The other piece it could be is the water pump drive shaft, that runs the gear for the cam driven water pump.
A picture would help a ton.
its the middle part sticking out.
the 1st optispark i replaced ddnt have 1 so i used it.
Yea i think its for the cam shaft.
heres an example
http://www.mamotorworks.com/corvette...1-140-804.html
heres an example
the 1st opti i bought from summit racing ddnt have 1. and now the 1 from oriellys ddnt either.and for some reason nobodys sells the opti with it.
yea it looks like i have to hit up the pick n pull
