Angle Milling
Angle Milling
What are the pro's and con's ? I have AFR heads with the 3/4 in thick decks. AFR offers angle milling from the factory as well.
Along with increasing CR, will it increase flow by standing the valves up?
Anyone have a link to a site that would could have some info?
Depending on what you're doing and the amount of the angle milling, you're going to have to run into all kinds of fitment and alignment issues. Headers, intake manifold, etc. There are reasons to angle mill, but not for the average guy with the average wallet and time.
Originally Posted by sawedoff
The thick decks are very advantageous in the strength they provide. You have less blown head gaskets, head distortion if you run it hot. The head is more resilient when you overboost, hellacious nitrous apps', blower apps'. It's all a win-win situation. If you have it together you won't have a head that lifts when you really pack in the PSI. You really don't want to redeck a head unless you just have to because of the aforementioned reasons. Alot of places will do it as a low buck way to raise compression, but that's like kissing your sister in the end.
So, I dont have any choice but to mill the heads to bring the CR up........
Originally Posted by LOnSLO
You could to a .075 to 0 angle mill, which would drastically drop chamber volume. Then just resurface the intake side to get your correct alignment back. Pretty common deal.
I am wondering whether there will be any increase in intake port flow, due to the angle milling, which will stand the valve up a bit. Increased flow = power gains there too....... ??
