Control Arm Relocation brackets
Old 11-14-2012, 06:46 PM
crazyforgms's Avatar
Default Control Arm Relocation brackets
I just pick up a rear end to replace the bent rear end in my 98 bird . the rear axle came with a ta diff cover & control arm relocation brackets can i used them on my stock bird and what is the reason for them?
thanks crazyforgms
Old 11-14-2012, 08:06 PM
ZForce1's Avatar
Lower control arm relocation brackets are for lowered cars. They correct a change in suspension geometry resulting from the axle sitting higher in the car after lowering.
Old 11-14-2012, 08:07 PM
bill12690's Avatar
I think the description here pretty much covers it:
http://www.umiperformance.com/catalo...roducts_id=117
Oh, and the TA cover is basically just a nicer, aftermarket cover for the rear diff. I believe it has a fill as well as drain plug...not a necessity, but def usable on an otherwise factory car.
Old 11-14-2012, 08:28 PM
thank you guys for the info helps me alot
crazyforgms
happy motoring
Quick Reply: Control Arm Relocation brackets
