AI 232cc 243 Heads
Old 11-17-2012, 01:53 PM
02TransAm/Batmobile's Avatar
Default AI 232cc 243 Heads
Anyone have this setup on their car? I was interested in one of their CNC programs but was wondering if how much is too much for an application?
"This is a slightly larger version of our 226cc CNC work that has consistently outperformed other CNC'd GM castings on the market, as well as most aftermarket casting based heads. The 226cc work being only slightly larger than the as cast port, would often leave some areas in the intake port untouched by the CNC cutting tool. While this is aesthetic and does not negatively affect performance, this slightly larger version will minimize or eliminate these areas of "non-cleanup." Most applications will not be negatively affected by the slightly larger intake port, and LS2's & strokers will pick up another few HP over the standard 226cc CNC work."
Old 11-17-2012, 02:10 PM
Super Hulk Smash
JakeFusion's Avatar
It'd probably run best on a 4" bore to be honest. Big cammed 370 or a healthy 402/408.
Old 11-17-2012, 02:31 PM
badazz81z28's Avatar
Honestly....Building up an LS1 seems like history repeating it self. This reminds me so much of the SBC / BBC debate.
For what people are spending for kick azz heads for a LS1 (Yes AI is Expensive), you get basically the same results with the 6.2 LY6/LS3 heads for less money.
If you looking to this extreme for all out performance, I would go for more cubes and better heads.
Old 11-17-2012, 02:37 PM
mac62989's Avatar
I remember Phil @ AI saying the bigger cubes guys benefit from this program. The 226cc is more than enough for 346's.
Old 11-17-2012, 06:38 PM
A.R. Shale Targa's Avatar
A 265 cc intake runner is quite large for an engine smaller than 400 inches.
I know GM puts them on 364 and 376" engines but the torque management
TB modulation helps create port speed at low rpms. A cathedral runner tends
to make more average torque throughout the power band;which moves weight
Quick Reply: AI 232cc 243 Heads
