lnc-2000 and nos launcher wiring?
LS1Tech Sponsor
LNC-2000 to NOS launcher
Are you activating the LNC-2000 off of one WOT switch and then the NOS launcher off of another?
What are you using as a WOT switch? The NOS launcher appears to be able to read TPS directly on either of the analog inputs so you wouldn't need to use a WOT switch. From the manual:
Then the launcher has programmable outputs that you could use to activate the LNC-2000 for timing retard. Again from the NOS Launcher manual:
http://www.holley.com/data/Products/.../199R10466.pdf
On the LNC-2000, it looks like you are activating 2-step function with the yellow +12volt input based on WOT? That would make the 2-step active when ever you were at WOT. I don't think that is what you want.
The orange +12v retard activation could come from the NOS Launcher but the 2-step activation should be clutch or toggle switch or brake activated unless you are using it as an overall RPM limiter (then it should always be active).
Is this a MT or an AT car?
The White/Blue wire is the “Input 1” wire. This is the trigger wire for the system. Connect to either a 12v or ground microswitch
input or it can be connected to the signal output wire on a TPS with either a rising or falling voltage. The signal type is selected in
the software configuration. If you are not sure which wire this is, consult a factory service manual.
So you could have TPS (not accelerator pedal) going to that.input or it can be connected to the signal output wire on a TPS with either a rising or falling voltage. The signal type is selected in
The Yellow and Orange wires are General Purpose Outputs (GPO’s) that are programmable in the software for various purposes
such as activating a timing retard, etc. These are low current ground outputs. If using to trigger a high current device (over 1
Amp), use them to trigger a relay. If you need a +12v output trigger, use this ground GPO to trigger a relay that will supply +12v.
If these wires will not be used, heat shrink the end and secure it tightly out of the way.
Here is a link to the NOS Launcher manual I was looking at:such as activating a timing retard, etc. These are low current ground outputs. If using to trigger a high current device (over 1
yea i have it wired like that now just wasnt workin , but i think it was a ground issue.
i have it wired like it says but they use a color code for the relay . which confuses me cause i dont use their relays . i make my own relay harness. cleans up wiring a bit.
i had the orange wire going to my switch instead of letting the launcher do it . i was just afraid i wouldnt know if it was workin or not. lol . but im learning to trust stuff.
how do u guys know if timing is being pulled ? anyway i can check without a tuner. i read something about the grey wire. but unsure
on the wot for on the 2 step that is being used on the clutch ,when the clutch pedal is 101% to the floor it supplies 12v. that way when i push it to change gears it dont activate.
just wondering what ur thoughts are on that. its on a 2010 camaro so no clutch sensor i dont think.
how would u do it or recommend doing the 2 step.
ty for the help . lnc is a awesome company.
