What is an adjustable suspension?
Old 11-20-2012, 12:30 AM
The Outlaw Kid's Avatar
Default What is an adjustable suspension?
I know what air bags are, but after that I'm lost. So what I want to know is what do adjustable parts like panhard bars, control arms, torque arms do? Do they control the stiffness or is there more to it than that?
How do you know when there adjusted right?
Can someone please explain this to me.
Old 11-20-2012, 01:30 AM
therealcreeper's Avatar
they adjust every aspect of the alignment, usually they have nothing to do with stiffness except in the case of something like an adjustable swaybar or shocks
caster
camber
toe
pinion angle
rear end offset
thrust angle
lower control arm angle
etc...
tirerack and a lot of other sites have some good information on what each one is and how it affects the car
Old 11-20-2012, 03:30 PM
caster
camber
toe
pinion angle
rear end offset
thrust angle
etc...
So is it just to make aligning everything easier. The reason I ask is I'm wanting to do the suspension on my Trans Am and I'm not sure which way to go.
Old 11-20-2012, 04:43 PM
JD_AMG's Avatar
Read the stickies at the top, thats what they are there for:
https://ls1tech.com/forums/suspensio...-tech-faq.html
If that doesn't answer more specific questions you have, then ask here.
Old 11-20-2012, 04:56 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
There are a lot of various reasons to go with an adjustable part, and just as many to not. If you would like some suggestions for which parts you'll want adjustable and why, I would be more than happy to help you out. Give me a call here at the shop and we can go over the parts you're considering and I can point out where the benefits of adjustable vs. non-adjustable come to play.
- Kevin
813-986-9302
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-20-2012, 09:00 PM
JD thank you for posting the link, I was using my phone earlier and couldn't find the stickies on the app. I'm going through them now.
Kevin I will be giving you a call when I finish my current project. Which I'm hoping won't be to much longer. But you know how it goes. I'm just trying to figure out where to go next really.
Old 11-21-2012, 02:40 PM
BMR Tech2's Avatar
Sounds good to me!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: What is an adjustable suspension?
