bulleye 94mm batmowheel or pt98?
looking for some input on which turbo to get the bulleye turbo looks amazing but not alot of people seem to use them. I am also local like 30 miles away from him and get a discount, the precision 98mm is a little cheaper and I know it will perform but kinda scared with all the issues that i have been hearing about the turbos blowing up.
what is the physical size difference in these also?
any other turbos that around that size that someone would recommend?
This is going on a 370ci,th400,9" car the motor will be changed out in the next year to go bigger prolly
thanks
thanks
I would buy local if I could, I don't know about the batmowheel but the borg warner billet set ups have been proven to perform. Plus being local if you need a larger turbine wheel when you go more CI you don't need to ship.
there is a buddy of mine that runs the moto wheel (80mm) with a stock cube motor and that thing made 1068 to the tire....I like them plus if your local then i would go that way for sure
correct me if I'm wrong but I believe bullseye themselves did a flow test with the batmowheel and the results actually proved that the cast piece actually flowed better, if thats the case you may even be able to get the cast wheel version for cheaper and I really like the BW/bullseye products they seem to be very well made and very very reliable.
94mm, 98, batmowheel, bullseye, cast, forced, inductions, lsx, performance, precision, pt, reliability, supercharger, turbo
