Old 11-27-2012, 07:56 PM
nj02z's Avatar
Default 233/239
Any opinions on tsp 233/239 cam on a stall auto car?
Old 11-27-2012, 08:01 PM
Tainted's Avatar
Yup just search for it
Good cam, some say its a bit large for a DD depending on what youre looking for.
Old 11-27-2012, 08:20 PM
BottleFedZ346's Avatar
I just installed this cam in my father's car to replace the Comp 224. cam, car gets tuned on friday so hopefully we get some good results!
Old 11-28-2012, 03:48 AM
nj02z's Avatar
It is not a dd but a toy that will see the track every other week.
Old 11-28-2012, 04:06 AM
FAD2BLK93's Avatar
Would a SS3600 work with this cam? Or maybe a little low for it huh?
Old 11-28-2012, 04:13 AM
Madellous's Avatar
I had this cam on a stock cube ls1 with a 3800 stall and a 112 LSA. This cam has a really nice lope to it but the power was a little high in the RPM range for my liking. I was running 3.23 gears so maybe a set of 3.73s can remedy that. IMO i would go with the Torquer V3
Old 11-28-2012, 08:46 AM
Tainted's Avatar
3600 would be just fine. im not a fan of huge stalls anyway, especially on the street. it gets old fast when your shifts constantly hover at 3000rpms with the 3800+ stalls. then again all stalls arent created equal so..
Old 11-28-2012, 08:50 AM
TXZ28LS1's Avatar
IMO, I think the 233/239 would be the biggest cam i would run in a daily driver. I actually have considered stepping up to that cam.
Old 11-28-2012, 09:22 AM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
We recommend at least a 3200+ converter for that camshaft. In my opinion I think that the 3600 would work even better with this camshaft.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 11-29-2012, 02:07 AM
99Bluz28's Avatar
I don't see it being a problem, a lot of people run larger cams in their DD .
IMO, run it with a 3600 Stall TC an enjoy it!
Old 11-29-2012, 03:49 AM
slowauto's Avatar
I have this cam in my car, and love it. Mine is on 114 lsa and in a 98 ls1 with stock intake. Only difference is my car is a 6 speed. cam pulls amazing up top but is a little sluggish down low. Ive outrun a couple of bigger cammed cars.
Old 11-29-2012, 04:13 AM
bww3588's Avatar
You would be surprised how much better power under the curve is over peak power...I've seen equal cars run faster on the street and track with smaller cams. One instance was an ms4 car and a tv2 car. Both were cam only with equal supporting mods. The tv2 car ran within .1 of the ms4 car and spanked it on the street.
Old 11-29-2012, 10:40 AM
Snkebait95's Avatar
I had the cam as well in a 5.3l 6 speed f body with 4.10s. I agree it felt a little sluggish below 2700 rpm, but i was never going to be in a race where im below those rpms. Unfortunately i didnt get any track times.
Old 11-29-2012, 11:29 AM
Summers6920's Avatar
Not to thread jack but how would that cam work in a m6 opposed to an auto?
Old 11-29-2012, 04:03 PM
99Bluz28's Avatar
IMO this cam will have it's tq peak higher in the powerband, and is more suited if you're spraying NOS on a regular basis, when compared to the Trq V2 or 3. So if you want your tq to peak lower in the powerband, and/or don't plan on spraying NOS then get the Trq V2 or 3 instead of the 233/239 cam.
Old 11-29-2012, 06:45 PM
3rdCoastPowerSports's Avatar
Without 4.11 gears (or something similar) Its a ******* turd on the streets. Not a daily driver cam in an M6 without gears. Dont get me wront the thing will haul *** from 3,000rpm to whenever your rev limiter kicks in but like 99BluZ above me said it will pull higher than your stock components will turn. The 233/239 sounds badass by the way. If you put it in an M6 make sure you swap gears or else a prius will beat you off the line and probably beat you to 35 mph as well. From experience running this cam in an M6. This cam is sick when launched over 4,000rpm with slicks. good times
Old 11-29-2012, 07:25 PM
wildcamaro's Avatar
Stalls and gears and that cam would be a good strip performer...
Old 11-29-2012, 07:26 PM
1994Z28Lt1's Avatar
With a stalled auto car and a good tune i wouldn't hesitate to run this cam on the street, I've spent a lot of time behind the wheel of a 00 LS1 with both the stock heads, then a while later ported LS6 heads. This car in an m6 and it just happened to have 3.42's still and a mail order tune. This car had the 112 LSA version of the cam and had a pretty damn lumpy idle (800 rpm) especially with the cutout open.
With stock heads and supporting mods it put down 380 at the wheels up from a baseline of 309 at the wheels. The ported ls6's made a huge difference however it hasn't been dynoed since.
It really is a high end cam though, if your looking for grunt around town I would look else where. This cam didn't really start pouring on the coals until after 3500 and pulled like a freight train from 4000 to the limiter at 6700rpm stock rod bolt beware!! But with a high stall and the right rear gears Im sure it would wake up quite a bit.
I'll also note that this car whooped up on a 12 mustang 5.0 M6 pretty hard all the way through.
one disclaimer though I dont care how much you guys love Pac and comp beehive springs this cam broke a pac 1518 exhaust spring in less than 4000 miles despite covering all the bases at assembly (checking installed height, pushrod length, heat cycle break-in, etc) This car also had stock ratio rockers. Maybe it was a fluke but it ended up bending that valve, luckily it was at low rpm so the piston didn't self destruct and saved the heads.
The car has a set of more expensive dual springs but it is damn good insurance.
Old 11-30-2012, 02:19 AM
FAD2BLK93's Avatar
So where would be the shift point of this cam with a forged bottom end? I would imagine the motor with this cam would need more than just good rod bolts right?
Old 11-30-2012, 03:51 AM
nj02z's Avatar
The car does have a Yank 4000 SS and 3:73 gears.This should handle it correct? Or is it still to aggressive for this setup?
Quick Reply: 233/239
