what should the plugs look like
yes... Rich in that one......LOL
but the timing mark on the strap is well defined...which is also a good indicator that you are in the right heat range...
if the timing mark isnt visible at all, you are too cold...if its visible, but looks blurry or smudged or smeared, then you are too hot
