Has anyone used the AEM wideband O2?
Just wondering if the unit is any good and can you log AFR vs. RPM.
http://www.scienceofspeed.com/produc.../NSX/AEM/UEGO/
Moderator
If it has an analog output like 0-4V or 0-5V you could
stuff that to your A/C pressure sender connector and
log it along with engine RPM using your EFILive/AutoTap/
HPTuners engine scanning/logging.
From the site. It would work great logging it through the A/C pressure sender!
I might pick up one...
SC-
EDIT: Er... $600 bucks! Maybe I'll wait on that...
I have a friend who can get me one at a discount through his car parts business. That's why I am looking at it.
I was reading in another post that the voltage is not linear with some Wideband O2 units and doesn't correlate correctly with AFR unless you use a look up table? or formula?
Can someone enlighten me on this? I don't want to have a $500 paperweight if I can't log RPM vs. AFR.
Turbo Addict
So is the pressure sender two wire or? I would unplug the sender, wire the WB output to the (+) side, ground the other or?
Speed Demon... does your friend have any in stock?
Thanks
Turbo Addict
he he... ahh too late, thanks anyways Brandon
well i just cancelled my WBC from dynojet and ordered an AEM unit.... so we'll see how it works when i get it.
I got mine through these guys: http://www.mentaladdictionmotorsports.com/
Ask for Beau..... he is pretty popular on turbomustangs website. I got a sweet deal on it and will have it next week... everybody else is on back order.
Let us know how it works for you.
I see they have one channel and two channel. What is the second channel for?
I imagine two channel gives the ability to measure both banks at the same time
Mine's sitting on the kitchen counter awaiting install. One in each downpipe. Not all turbo guys need just one channel
Turbo Addict
On another note... glad to see your still kick'n.... been quiet for awhile now.... got any new dyno numbers?
