Need help...
Need help...
I just did a battery relocation to the trunk. Upon starting the car the car rpms will jump to 3k then tries to die. If I feather the gas pedal for a few seconds the car will then Idle. After that it I rev the car very slightly the rpms will jump to 3k and hang for about 5 seconds then falls very slowly.
Nothing was changed on the tune at all. Any ideas what could be causing this? maybe a ground? or does the pcm have to re learn after being disconnected from the power source?
Thanks in advance.
Thanks in advance.
Also, all your long term fuel trims will have been reset. I would double check grounds and verify the voltage at the front vs at the battery. Injectors work off a voltage scale so if they are seeing less voltage than previously they will be working off of a different offset table.
