Turbo Race Car Part Out
Category: Racing Parts
Price: $99
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): MI
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Nasty Performance Race Fuel System
*All brand new, never used!*
-Nasty sumped tank
-Racetronix 120# Injectors
-Injector Converter Box
-Magnafuel 4303 pump
--10an feed and return line (black)
-all black fittings
-Nasty polished fuel rails
-Rest of components to make it a complete Nasty Performance fuel system good to 1200+ on e85 or 1500+ hp!
$Sold!
Thompson Motorsports Forged 370 Shortblock
*Brand new in the shipping crate*
-Set up to be 9.5:1 with 317 heads
-GM iron block
-GM crankshaft
-Eagle forged rods with arp2000 bolts
-Diamond forged pistons (flat top with valve reliefs)
-Steel top rings for high boost
-ARP Main Studs
Thompson Motorsports CNC 317 Heads
*Brand new from Thompson
-CNC ported
-Stainless Steel Valve upgrade
TH400 tranmission
*Brand new from Detroit Gearbox*
-100% fresh, built to handle 800+hp.
-RMVB with Trans Brake!
Pro Torque Revolution Converter
*Brand new in the box*
-Set up for the car, twin turbo 370ci, for ~800rwhp
-Includes a TH400 SFI flexplate and adapter this was made to bolt to
Turbonetics TC72 turbos
*Brand new, never ran*
-T4, 3" V-banded downpipe exits
-.81 a/r's
-journal bearing, polished housings
-72mm compressor wheels
-68mm turbine wheels
$1375
Vehicle as roller
-1998 Trans Am
-White, anniversary replica in *red*
-115k miles
-no engine, trans, or seats
-Entire car just received fresh paint, professionally done including engine bay!
-Heater core was removed behind dash already
-PA Racing Super Turbo Style K-member
-PA Racing tubular Upper and Lower control arms
-Strange front SA Coil Overs
-QA1 rear SA shocks, Pro kit Springs
-PA Racing body mounted Tq. Arm
-Founders LCAs and PHR
-Bolt in LCA Relo. Brackets
-98 PCM and harness included and still installed
-10 bolt with 3.23's
-stock driveshaft included
-Front mount intercooler bolted to core support
-GM WS6 Hood
-WS6 wheels, fronts narrowed with fresh 185/55/17 M&H, rears have fresh MT DR 275/40/17
Not available anymore, decided to keep!
Will get more pictures up ASAP
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
It would need a good rear end which was the last piece of the puzzle! Needs a seat, components to finish the TH400 install like shifter and linkage (I forgot a BMR crossmember is included, flex-plate and adapter also included with the Revolution converter) Then to finish up the top end and add your power adder if desired (Twin TC72 turbos in there)
__________________
__________________
Everything is great, just would rather do a few other things at the moment rather than have a race car is all!
__________________
I forgot an important part to the Nasty Fuel System. Included at this price is also a set of Brand New Racetronix 120# injectors w/ Converter Box! Updating first post with it!
__________________
__________________
Bump for some awesome parts!
__________________
Fuel System SOLD!
__________________
Currently none, but I have a brand new Griffen I would throw in with the roller!
__________________
Yep! Txt sent!
__________________
