Nitrous dual stage help
I had the hsw plate kit for my ls6. This year I decided to upgrade to a fast 92mm. I want to run 2 stages this year. I was hoping for some insight on how to plumb this. I was going to purchase the nitrous outlet 2 stage plate. However I don't know what fittings to get to y into two solonoids. Or if I should just say **** it and sell my hsw kit.
Depending on what solenoids you already have depends on what fitting you need. We can definitely get you taken care of.
If you are looking to hit 2 true stages you are going to need 2 more solenoids. 1 set will open for the first stage, the second set will open when you want the second stage. If you why the solenoids together than you will be hitting both stages at the same time essentially making it a single stage broken into 2 different discharges.
Let me know what you go and we will get you taken care of.
