5.3l etc help!
Old 12-31-2012, 07:16 PM
L_maddog's Avatar
Default 5.3l etc help!
So I need some help, I have a 2001 5.3l that came out of a gmc yukon the yukon came with drive by wire setup ....unfortunately, well I put the motor in an s10 , I did the harness myself, and everything ran great I drove the truck for 2 months before now , what happened is Ill be going down the road or stopped and the pedal goes out on I have no throttle at all, and the mil lamp comes on and it goes into limp mode, I got a scanner tool and put it on there and coming up with the codes p1516 p1518 and p1571, I delete them while the truck is running and put it in gear, and press on the gas and it works until a couple of feet and it goes into limp mode with the mil lamp on and the pedal goes out again, I don't get it really, I can't find any forums with anybody's pedal going out, just them throwing those codes
Old 01-01-2013, 05:11 AM
Ron_Stoppable's Avatar
Are you only able to get "1/4th - 1/2th" the throttle response? You might wanna check this out. Its the code your getting also. I would ditch the DBW tbh though.
https://www.youtube.com/watch?v=U2Dj...e_gdata_player
Old 01-01-2013, 06:32 AM
Old Geezer's Avatar
Maybe try the diagnostic and tuning forum??????????
Old 01-01-2013, 08:36 PM
LS1MCSS's Avatar
P1518 is no communication between TAC and PCM. Sounds like you have a bad connection. Did you do anything with the wires for the TAC when you modded the harness? If so, did you use solder and heat shrink on the connections?
Quick Reply: 5.3l etc help!
