Founders 3 Piece Poly Joint
If all you care about is driving in a strait line, then poly is "fine". If you care about ride quality and handling at all then look into either solid 1LE bushings for the stock LCA's or UMI rotojoint.
Isnt the Roto Joint basically the same design as the 3 piece poly joint? The roto joint is out of my budget
I have the 3-piece poly and they articulate to a large degree but are still firm. My main concern was that they dont have a grease fitting, but they say re-greasing is not necessary. When you assemble them, the grease and 3 pieces form an insane vacuum inside the ends so im not worried about it.
I noticed zero harshness increase in daily driving, when added to my Bilstein/BMR spring setup. The car was already hell on bumpy roads and on smooth surfaces it's a dream.
I wish they made the 3piece poly for front lower control arms, I would buy them in a second.
I've been looking into these control arms myself. The design has been around for ages, just took a bit for them to be applied to F-bodies.
Would be a good question for Founders why they don't have a grease fitting on them.
I still would like to see a direct comparison of roto joint vs poly joint vs rubber for handling and ride comfort. I'm guessing it is something like rubber > poly joint > roto joint for ride comfort for example, and the opposite for handling, but how much of a difference between each one?
I need to buy stuff for my car this year and I only want to make purchases once. I don't have money to just buy something, decide it isn't right, and buy something else, etc. I'd rather get the right part for me the first time.
We don't install grease fittings on these for several reasons. We supply a specially designed water proof grease with the arms and we have found if you use the grease properly you should never need to re-grease them. Second reason is when the bushing assembly is installed the grease has no paths to allow for proper grease flow, we have also discovered the manual pumping grease guns when hydro locked tend to spike up to around 10,000 psi and will destroy any bushing in its path.
For those of you who are comparing our poly-joint to the roto-joint I would recommend looking at our pivot-joint instead.
Forgot about that one.
So here's a question for you - which one would you recommend for a street driven car to be set up more towards handling than drag, but daily driven? I'm thinking the 3 piece poly would be a good happy medium between articulation and comfort. Swivel joint is more performance oriented at the sacrifice of comfort. Would you agree or would you suggest something else?
Wow well than i wont be needing to grease them, i ordered the 3 piece on car adjustable lcas and a no car adjustable pan hard from founders. should be here soon ill post pictures and write a review on how the car feels. Adjustment wise should i just center the tire in the wheel well?
