Headlight grinding sound
Old 01-12-2013, 12:06 AM
DatsikWS6's Avatar
Default Headlight grinding sound
Hello everyone. Last night, i went to shut the headlights off on my 98 trans am and when they closed, the driver side one made a sound like it was jammed or like the light just wanted to keep going down. The sound lasts for about 10 seconds then goes away. Another thing thats wierd is the whenever i go to lock or unlock the car with the remote, the headlights pop up then go back down. They never use to do that until last night at the same time the noise started. Any thoughts would be much appreciated, thanks.
DatsikWS6 is offline
Old 01-12-2013, 12:35 AM
Anderson0741's Avatar
You have a stripped headlight gear, you can replace it with another plastic one, or you can replace it with a brass gear and the problem will go away. The headlights go up and down to tell you it has a problem.
One like this
http://www.ebay.com/itm/2000L-2004-C...ff1970&vxp=mtr
Anderson0741 is offline
Old 01-12-2013, 12:41 AM
((((((Administrator))))))
CRAGER's Avatar
Exclamation
General Maintenance & Repairs
Leaks | Squeaks | Clunks | Rattles | Grinds
General Maintenance & Repairs FAQ -- PLEASE READ BEFORE STARTING THREAD
Firebird Headlight Noise Or Odd Behavior
https://ls1tech.com/forums/showpo...7&postcount=16
CRAGER is online now
Quick Reply: Headlight grinding sound
