AiResearch Garrett Turbo
Old 01-17-2013, 02:34 PM
LSX FOX's Avatar
Default AiResearch Garrett Turbo
Ok so what ive got is a 76mm t6 flanged AiResearch turbo with a 5" vband downpipe..what i want to do is put a t4 rear housing on it with a smaller downpipe due to space..i know ive heard that i have to get a t4 exhaust turbine for the rear and a t4 housing. anyone know who would sell this part or if that is even correct of what i need to do?
Old 01-17-2013, 03:24 PM
typhoon1015's Avatar
just neck down the DP from 5 to 4 inch?? Keep the T6 if you can
Old 01-17-2013, 04:55 PM
LSX FOX's Avatar
i could try that but its more of the turbo is allready huge and the 5" downpipe just makes it even worse..ill just try that though, i thought that could screw the seals up in the turbo if it had to much bad pressure and couldnt flow the exhaust out fast enough..but i wont be running that much boost anyways since the turbo is so big..thats another reason i wanted to go with a t4 rear houseing so that it will spool up faster..i mean this turbo is huge.
Old 01-17-2013, 06:19 PM
F110Mech's Avatar
Forced Inductions can probably get you anything that you need
Old 01-17-2013, 06:38 PM
Ping King's Avatar
Just neck down the downpipe. no biggie.
Quick Reply: AiResearch Garrett Turbo
