18" C5 DD with spacer/adapter
I am about to order a pair of 15mm adapters for the rear of my ws6.. Currently running a staggered set of 17 x 9.5 and 18 x 10.5 C5 DDs. With the 56 mm offset of the 18s, this would equate to 41 mm offset (right?), which according to the sticky seciton is still ok, but I am mainly just lookin for pictures to confirm that this wont push it beyond the fender (which I intend on rolling).. Any help will be much appreciated. Thanks
i dont remember what size spacers i got, i just know that my mission was to find the smallest spacers at the local performance shop...
and they do rub a bit on unrolled fenders with 295/35s on the back, but only on higher speed turns
hey nichoLaS1 did you ever get these spacer installed, i was curious as well on how these would look with 18x10.5 wheels. also the firebrid/trans am has bigger fenders then the camaro so hopefully you can get away with not rolling the fenders. best way to check is to remove the rear springs with the body on jack stands and the axle on the jack, then remove the rear springs and jack the axle up to the bump stops. check for clearance and adjust as needed.
The tires already rub some on hard turns so Im gonna have to roll them
Looking good! I know this isnt the subject of this thread but I was curious if you plan on rolling your fenders yourself? or at a shop?
I went to a shop the other day that's rolled fenders before and they looked at mine on my 98 ws6 and said he can guarantee that if they roll them the paint will forsure crack, so no way im taking it there.
Im pretty sure i could get away with them not cracking since it looks like it needs minimal rolling. Just trying to get others opinions on the matter and curious if anyone else has done it on there trans am and what there experiance was like..
What size are your rear tires? I was thinking of getting a 15mm spacer. I have Toyo R888 315's in the rear. Need to roll my fenders though. Wouldn't happen to have a link for the spacers you got would you? Pm me if you can't post the link
Talk with Lenny at Motorsport Tech, they will make any custom spacer you need.. check the "bargain bin" on the website occasionally.. that's where I got mine
DO. NOT. USE. A. BAT. Unless you don't care about your paint please don't do this.. I considered it before I found the tool, and although I haven't personally tried it, after I actually rolled them I'm glad I decided against it.
Key points to remember.
1) Keep the paint warm when rolling.. even when rolling the fender try to keep heat on it, but make sure to avoid keeping the heat gun in one area as this can hurt the paint.
2) Start at the top of the fender and gradually work your way outward.
3) DON'T rush it and DON'T apply too much pressure.. the tool has an adjustable-angle wheel that rides on the fender lip. It is critical that you only try to roll a small angle at a time (i.e. do not try to fold the fender completely inward on one pass) I figured it was one of those things that its better to be safe than sorry and actually probably took more time than necessary.
4) Don't forget longer wheel studs
