99 to 01 OS Hptuners doesnt read sensors
I changed from a 99 tune OS to an 01 OS and now the sensors aren't reading, STFT, LTFT, TEMP, TACH etc... only O2 sensors whats going on?
Moderator
Have you validated the config file you're using? Reusing
one that worked before, may not play so well.
Now I do not ever recall seeing the PIDs referred to in
that way (TEMP, TACH). If this is how they're called
out, and you're using the "sensor" instead of direct
PIDs, maybe the "sensor" definition is jacked.
Try deleting everything from the table view and then
repopulate it by hand from the PIDs that are valid.
