How to clean surface rust off of ls1 spindle?
I have some ls1 spindles I am getting ready to swap into my lt1 camaro. I'm on the fence between cts-v 4 piston calipers and z06 rotors and s0b 6 piston pbr calipers or ctsv 6- piston calipers. I think I will use 14-14.5 inch rotors just not sure about the details yet.
However in the meantime I have an ls1 front sub-frame sitting in my driveway out of a 99 trans am, engine/tranny kmember, and all collecting rust on the spindles. Would wd-40 or coke be ok to clean with? Sand paper, wire brush, towel soaked in coke?? Not sure because I don't want to damage anything. I would worry about cleaner getting into the wheel bearings and messing them up. I don't want to replace the wheel hubs so I just want to know if it would be ok to get/soak it all in coke or wd-40. Would those damage or clog the wheel hub or make it sticky etc. so the wheel doesn't turn freely. If I'm totally off base let me know. I feel like the wheel hubs shouldn't be exposed but I figure before I do anything I should ask.
Also, Is it safe to go ahead and just paint the whole thing? Or do I have to worry about getting paint in the wheel hub too? I just want to prevent rust so I am going to use some spray paint to keep the rust off. Probably some caliper spray paint. Either black or red, maybe blue lol xD. I like exotic colors but like I said, I really just want to prevent the rust from coming back. Right now surface rust is spreading and little dots are appearing all over the spindle. I want to save them before they are unusable and I don't want to buy new spindles and hubs because gm parts direct sells them for like $300 each so that's way to expensive.
Thanks.
Thanks.
The rust isn't too bad, really. But its ugly as hell orange and sat out in the rain for a week or two.
So far I am trying to decide between powder coating and por 15. I plan on tracking the car so heat in the caliper is sort of a big deal. I hear the por 15 doesn't do a good job of dissipating heat when used as caliper paint? I really have no idea because its all just hearsay but the black does look really good in the picture.
And my spindles look roughly the same as the ones pictured.
