Foxbody Wiring help
Foxbody Wiring help
I bought a roller mustang and im putting an ls motor in and the wiring harness was taking out. I need help putting it back in. Does anyone know what wires I can take out and a pictures of the wires to keep. Thanks
LS1Tech Sponsor
the ls engine harness or the fox body harness?
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
I was in the same situation with my harness. You may just want to keep all the plugs to keep the harness intact or else it quickly gets out of hand trying to simplify it. In my opinion it is not worth trying to strip down a factory harness because you will still have a factory old brittle bunch of wires. Just my 2c...
which harness was taken out? The engine harness or the body harness under the dash? If its the engine harness you dont need any of it except the oil and temp sender wires for the gauges if you are going to be using stock gauges.
