96 WS6 Formula
96 WS6 Formula
Year: 1996
Make: Pontiac
Model: Firebird
Price: $8000
Mileage: 70000
Private or Dealer Listing: Private Listing
Location (State): MS
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
We are the original owners to the car, ordered it from Anderson Pontiac in Baltimore, MD. 70K on car, 21K on crate engine that warranty replaced because the oil pump pickup fell off, 36K on trans that also was replaced under warranty for popping out of gear. It has quite a few mods done over the years. I have all paperwork from when the car was shipped to the dealer to now. I did sell the car in '01 to a co-worker with 58K miles. He had the car until I bought it back in '09 with 60K miles. So you can see it basically sat in his garage the entire time he owned it. I can tell you anything you want to know about the car. Here's the mod list for those interested, car ran a best of 12.44@111 on a 1.75 back in 2001 right before I sold it. That was the last time it was at the track. Car runs great, took it up to Oxford and it got 25mpg on the round trip. Everything works. Only 2 problems right now, the windows going up and down real slow. I did buy 2 brand new AC Delco window motors that will go with the car, just haven't had time to put those in. The gears whine in the rear, more annoying than anything else but that's what the radio is for I'm sure I'm leaving something out but that's pretty much it.
Engine:
Reprogrammed '95 computer
LT4 HOT cam and extreme duty timing chain
Crane Gold 1.6 roller rockers
IRS valve springs
Crane Hardened push rods
Felpro .039 head gaskets
TPIS GM 52mm throttle body
SLP air foil
Meziere Electric Water Pump
March underdrive pulley
Trans:
Hurst Billet Shifter
RPS Turbo Clutch
ACPT Carbon Fibre Drive Shaft
Poly Trans Mount
Suspension/Rear:
13" front Corvette brakes
Kenny Brown Double Diamond Sub-frame Connectors
Hotchkis PanHard rod
LG Motorsports G-Load Brace and Driveshaft Loop
BMR Shock Tower Brace
Superior 4.10 gears
Nitto Drag Radials in rear, General's in front(7K miles)
Exhaust:
Coated SLP dual cat headers
Stock dual cat y-pipe
Borla intermediate and over the axle y-pipe going into SLP 2 on the left muffler and tailpipes. Passenger side is SLP intermediate going into an SLP splitter. Looks like the SLP Dual/Dual but is completely adjustable like the Borla
Misc.:
LT4 knock module
Accel 300+ ignition
Harland shift light(not working)
Haynes Transmission Cooler(used for power steering cooler)
Adjustable Fuel Pressure Regulator
Fernco coupling on intake
MBA Throttle Body cover
1LE Aluminum Drive Shaft(not in car)
Asking $8000
Thanks
Throwing this back up
Here is the NADA Classic Car value:
http://www.nadaguides.com/Classic-Cars/1996/Pontiac
Pick Formula and then click WS6.
Just in case a buyer clicks the link and it shows a lower figure like when I clicked it.....you have to go back one page and check the box for WS6 package. That option adds $2000 to it on NADA. Also I had to enter my zip code, so I'm not sure but value may be different according to where you live. ??
