Need advice for turbo 4.8 fairmont budget build
Old 01-29-2013, 02:48 PM
AJGls1's Avatar
Default Need advice for turbo 4.8 fairmont budget build
Picked up a 79 fairmont today and im wanting to do a turbo 4.8 build. i have the 4.8 and aje k member with ls mounts, need some suggestions on what turbo to run, was thinking about a on3 70 or 76 or a mp70 but have also seen people have good results with gt45s off ebay. hoping for 500-600 at the wheel. should i go with the ls6 cam? stock heads or find some 243s or? trying to do this fairly cheap so an $1000+ turbo is out of the question. plan on doing head studs but are rod bolts a good idea also? was planning on running truck intake but if it doesnt clear hood go with ls6 or? any advise will be helpful. hopfully get some pics up soon but will be gathering parts for a little bit.
Old 01-29-2013, 03:00 PM
F110Mech's Avatar
https://ls1tech.com/forums/forced-in...l80e-sold.html
annnnd go.
Beanslsxnova's Avatar
Pm denmah. I'm sure if anyone could get you straight it would be him with a fairmont on a budget.
Old 01-29-2013, 03:04 PM
AJGls1's Avatar
ive looked thru denmahs build quite a few times and know what he ran, guess it worked for him so i should just copy. need suggestions on fuel system to, plan on sumping the stock tank.
Old 01-29-2013, 03:05 PM
AJGls1's Avatar
anyone running a gt45 who did u get it from off ebay?
Old 01-29-2013, 04:06 PM
redss82's Avatar
Vsracing he is has a 80mm and 76mm in the works too
Old 01-29-2013, 05:29 PM
a4ls2goat's Avatar
Dnamotoring on eBay for 260$.
Quick Reply: Need advice for turbo 4.8 fairmont budget build
