Aftermarket LSX block question
So I bought a used LSX block from a member on here and I was just inspecting it over and I notice the the top of 6th bolt hole is not maching for threads.
Is this common and they need to be machined ? Why wouldn't this be machined I want to use all 6bolt holes so this doesn't make sense to me.
I am confused!!
I am confused!!
Getting in there is doable with these. You may have to grind a little on these, or grind the block. I have done the block in the mill for additional clearance. The aluminunm ones need it to.
Snap On FRDH121 for 3/8" (torque adapter)
Snap On FRDH141 for 7/16" (torque adapter)
These are for 12 pt nuts.
