Looking at a gear swap some question's on Motive's
I bought my 02 WS6 just in fall and I'm looking at a couple of mods particularily a gear swap from the stock 3.42's.
My car is an M6 car with 425rwhp and it will be a street car only mostly city with the odd highway run. Stock tire height.
My buddy said to get the Motive's that have the longer part # as they are lapped in from the factory and the better ones to get. Anyone know if there is different part #'s in the Motive line?
Are the stock diff's made by Borg Warner?
Still on the fence on a ratio choice looking at either 3.73's or 3.90's I just find first gear really tall and with sixth being so over driven a gear swap would make it nicer to drive in the city.
Also where is a good place to purchase Motive's for a good deal.Thanks.
advance carries the motive brand ata decent price but the 390s are discontinued through them but summit still has them for $200. 373s at advance were about $180 for ring and pinion. the gm rebuild kit was $70(bearings,shims etc) motive part numbers were gm7.5373or gm7.5390 (the7.5being the rear end depending)
Motive part numbers: GMxxxxx = stock like quiet
.................................G8xxxxx = noisy and less forgiving about how they are setup.
My experience. And all gear sets are lapped in after they are made so you're friend is
01ss is right. The motive are all lapped at the factory and they don't make 3.90s in the normal street headset you will have to get the orange box gears which as said do tend to be a little noisy.
Mine have a touch of whine on decel but you have to really listen for it, on top of that they are a little stronger alloy which Is why they tend to make a little noise. In happy with mine I feel it's a great ratio for the m6
