A new LQ4 block
Old 03-07-2003, 11:19 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Default A new LQ4 block
If one where to buy a new LQ4 block, would it need any prep work or can the internals be bolted in?
Old 03-07-2003, 01:42 PM
LQ4somona's Avatar
Default Re: A new LQ4 block
Depends. If you are using a rotating assembly out a LQ4, just buy the new pistons, rings and bearings to assemble the engine. But if the rotating assembly is out of an LS1 you would still need to buy new pistons, but the rest of the assembly would need to be balanced for the engine to work descently.
Old 03-07-2003, 02:05 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,221 Likes on 778 Posts
LS1Tech 10 Year
Is the question whether the block ready freddy? Always a good idea to check the bores but it should be okay.
