v6 rear brake backing plates
Old 02-24-2013, 11:29 AM
k_garretson23's Avatar
Default v6 rear brake backing plates
are the baking plates on a v6 rear end the same as an ls1 car's rear end? Looking to upgrade to an s60 so I need some backing plates, and there is a v6 car in the junkyard. also are 4ch and 3ch backing plates the same?
Old 02-24-2013, 12:13 PM
Carl at CRP's Avatar
The backing plates are the same v6 or v8.
4-ch backing plates have a hole for the sensor, 3-ch backing plates do not.
Hope this helps.
Carl
Old 02-24-2013, 12:21 PM
great thanks a lot! if the car in the junkyard is a 3ch car, could I just drill the hole? would there be an issue with this?
Old 02-24-2013, 12:26 PM
The location of the hole for the sensor is critical, I don't recommend drilling a 3-ch plate to make it into a 4-ch unless its done on a vertical mill with a 4-ch plate for a reference.
Carl
Old 05-07-2017, 08:41 AM
fastlt1's Avatar
But I guess lt1 and ls1 backing plates are different
Old 05-07-2017, 12:04 PM
01ssreda4's Avatar
Carl is correct and yes LT1 plates are different due to parking brake design.
Quick Reply: v6 rear brake backing plates
