Valvespring question
Old 02-27-2013, 01:22 PM
badblazeSS's Avatar
Default Valvespring question
My brother and i are about to turbocharge our cars. We are both going to run ls6 cams, pump gas. My question is will the stock ls6 springs be ok to run or should i upgrade to aftermarket? I have a set of patriot dual gold springs i believe are good to .650. Is that too much spring to run on a ls6 cam? I appreciate the input.
Old 02-27-2013, 01:38 PM
1999Black_Z28's Avatar
Nope, the stock springs will not work. The patriot golds are fine for the LS6 cam. Another good option is Brian Tooley
Old 02-27-2013, 01:41 PM
Moderator
denmah's Avatar
pac 1218s are a great budget spring for a mild >.600 lift cam
i also run them in stock cammed turbo motors to keep the valvesprings shut
Old 02-27-2013, 01:54 PM
badblazeSS's Avatar
where would be a good place to buy these pac 1218's? Brian Tooley have a website?
Old 02-27-2013, 02:03 PM
badblazeSS's Avatar
Nevermind, I found the site. Wow, Brian Tooley stuff is very affordable.
Old 02-27-2013, 02:56 PM
Moderator
denmah's Avatar
sdparts.com
140 dollars for the springs
Old 02-27-2013, 03:26 PM
LS1Tech Sponsor
hellbents10's Avatar
We made 747rwhp with LS6 springs, we switched to 1218s and picked up zero hp anywhere. This was a stock LS2 with a 72mm turbo on it. Valve springs had 35k miles on them like the rest of the long block.
It will be an age old argument but a properly sized turbo on a engine will have zero effect on valve spring pressure. It just operates like it is on a different planet with more atmospheric pressure. There is a lot going on the other side of the valve too. Camshaft and valve train weight play more of a roll on spring pressure.
Quick Reply: Valvespring question
