question about l92 stroker kit and the heads?
Old 03-01-2013, 08:35 PM
royaldxb's Avatar
Post question about l92 stroker kit and the heads?
hello, my engine have a major damage and i'm thinking instead of repairing the pistons and probably the crank shaft. can i install a stroker kit without changing my stock head? i'm not sure how it's done and i don't have enough experience.
this is the stroker kit i'm willing to buy: stroker kit
please help
Old 03-01-2013, 08:43 PM
anheuserbusch08's Avatar
yes you can
Old 03-01-2013, 08:45 PM
Tainted's Avatar
Yea but youre gonna want to have the heads checked. Valves springs etc.
Old 03-01-2013, 09:18 PM
royaldxb's Avatar
thank you for replying guys. so what do i need to change or upgrade in my stock engine to install the stroker kit?
Old 03-01-2013, 09:22 PM
Tainted's Avatar
Everything lol. Take it to a machine shop. The whole block needs to be checked and possibly cleaned up. New crank rods pistons bearings rings bolts gaskets balancing assembly
Old 03-02-2013, 01:06 PM
batboy's Avatar
And the cylinders need to be honed to fit the new pistons. I recommend having the machine shop check the block to make sure it only need to be honed to 4.070" before buying that rotating assembly (besides, I'm not a fan of Scat parts). When you say the pistons had major damage, I cringe at the thought of what the bores might look like. I bet machine shop labor rates are probably more than you think. Honestly, if the old motor let go, I'd probably just buy an assembled forged stroker short block. Check out these from Texas Speed:
http://www.texas-speed.com/p-295-tsp...ort-block.aspx
Quick Reply: question about l92 stroker kit and the heads?
